FWSM flash fsck
vciric
I have two 6513 chassis. There is one FWSM in each 6513. “Sh disk” shows that FAT is corrupted on both FWSM modules.
# show disk:
-#- --length-- -----date/time------ path
  1 0          Jan 24 2008 17:18:38 .private
  6 0          Jan 24 2008 17:18:38 .private
11 0          Jan 24 2008 17:18:38 .private
16 0          Jan 24 2008 17:18:38 .private
21 0          Jan 24 2008 17:18:38 .private
26 0          Jan 24 2008 17:18:38 .private
31 0          Jan 24 2008 17:18:38 .private
36 0          Jan 24 2008 17:18:38 .private
41 0          Jan 24 2008 17:18:38 .private
46 1981       Mar 04 2008 13:57:00 old_running.cfg
47 7351       Feb 22 2011 02:07:54 admin.cfg
48 42690      Feb 25 2011 13:27:40 Serveri.cfg
59668480 bytes available (79872 bytes used)
File Allocation Table might be corrupted. Recommend running "fsck disk:"
After running "fsck disk:" on both FWSM the following message appears:
fsck disk:
Checking the boot sector and partition table...
Checking FAT, Files and Directories...
Reclaiming unused space...
Updating FAT...
Destroying old disk cache...
Initializing disk: cache, please wait.....Done.
fsck of disk: complete
WARNING: Restoring security context mode failed.
Could this happen because of corrupted flash? What steps would you recommend to resolve this issue?
mirober2
If 'fsck' doesn't fix the corruption, you can use 'format disk:' to completely reformat the flash. You'll need to be sure that you have backup copies of your configuration files and FWSM/ASDM images as this will completely rewrite the flash.
If a 'format' still doesn't fix it, you would need to open a TAC case to get replacement units.
Hope that helps.
-Mike
mirober2
Hope that helps.
-Mike
Will "format disk:" destroy maintenance partititon?
Vesna
Hi Vesna,
No, the maintenance partition is left in tact. The format command only affects the partition that you are booted into.
Hope that helps.
-Mike
