h323 inspect in a single class with match criteria
hansrodlo
Hi, I trying to apply this to make sure only inspect h323 traffic in a single host (that's a Video Conference host), but don't works. Only works when I applied the inspect in the inspection_default class.
Here is the config:
access-list 100 extended permit ip host x.x.x.x any
access-list 100 extended permit ip any host x.x.x.x
class-map h223_VC
match access-list 100
policy-map global_policy
class inspection_default
  inspect dns preset_dns_map
  inspect ftp
  inspect ip-options
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect pptp
  inspect icmp
  inspect netbios
  inspect icmp error
class h223_VC
  inspect h323 h225
It´s possible? or is something wrong?
Thanks a lot for your help
Luis Silva Benavides
When you have it in the global policy you only H323 H225 or you also have H323 ras?
What do you see if you run this commands?
packet-tracer input tcp 1025 1720
sho service-policy flow tcp host host  eq 1720
How do you test it?
Luis Silva
"If you need PDI (Planning, Design, Implement) assistance feel free to reach"
http://www.cisco.com/web/partners/tools/pdihd.html
Luis Silva
Hi Luis thanks for response,
No, only have h323 h225.
When Its applied in the inspection_default class, the video works in both directions, but when I remove it, and apply in a single class (with desire criteria), the video only works in one way. It's same result, when I remove the inspection from the inspection_default class.
Un saludo.
