Hardware Check
samgaming
hi guyz
need a little help
here is the scenario "i want to check the hardware/inventory installed in a router i cant physically see"
Problem"when i run command(sh inventory or sh controller or sh diag) they give me result showing that 2 VWIC G.703 Card installed.
when i run command(sh hardware) it shows me 6 serial ;4 E1 Slots and some gigi ports(which are builtin)
when i run command(sh ip int bri) it shows me some gigi and 3 serial ports to be UP
when i run command (sh run) it only shows 3 serial and some gigi ports
Question
how can i confirm that i have serial available and if available why only sh hardware command shows that.
i hope you have understood the question
Waitin for replies
5 Replies 5
Farrukh Haroon
This forum is about the Cisco 'MARS' product :)
However this can happen due to numerous reasons, Chinese counterfeit hardware, Incomptaible software version that does not support the hardware, hardware failure.
Mostly its the first two reasons. Which cards are these exactly, and which one is not showing exactly?
Which router model?
Farrukh
sorry for posting in wrong section
the router is cisco 3845
i have no idea wht cards are physically installed in it ; i only have remote access and it is only showning 2 VWIC cards.
You can see the VWIC cards with the show diag output, can you post the output here?
Farrukh
Slot 0:
C3845 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapt
er, 9 ports
Port adapter is analyzed
Port adapter insertion time unknown
Onboard VPN : FW ver01100200
EEPROM contents at hardware discovery:
PCB Serial Number : FOC11090PS8
Hardware Revision : 1.3
Top Assy. Part Number : 800-23616-05
Board Revision : B0
Deviation Number : 88343
Fab Version : 05
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 69
CLEI Code : IPME110BRA
Product (FRU) Number : CISCO3845-MB
Version Identifier : V05
Chassis MAC Address : 001b.2ae2.d510
MAC Address block size : 48
Part Number : 73-8799-08
Hardware date code : 20070227
Chassis Serial Number : FCZ111172AR
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 31 30 39 30 50 53 38 40
0x10: 04 2C 41 01 03 C0 46 03 20 00 5C 40 05 42 42 30
0x20: 88 00 01 59 17 02 05 03 00 81 00 00 00 00 04 00
0x30: 09 69 C6 8A 49 50 4D 45 31 31 30 42 52 41 CB 8C
0x40: 43 49 53 43 4F 33 38 34 35 2D 4D 42 89 56 30 35
0x50: 20 D9 02 40 C1 C3 06 00 1B 2A E2 D5 10 43 00 30
0x60: 82 49 22 5F 08 83 01 32 3F 53 C2 8B 46 43 5A 31
0x70: 31 31 31 37 32 41 52 FF FF FF FF FF FF FF FF FF
WIC Slot 0:
E1 Drop&Insert & G.703 (2 port) WAN daughter card
Hardware revision 1.0 Board revision B0
Serial number 35016462 Part number 800-06724-03
FRU Part Number VWIC-2MFT-G703=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 30 01 00 02 16 4F 0E 50 1A 44 03 00 00 00 00
0x30: 58 00 00 00 06 06 08 00 FF FF FF FF FF FF FF FF
WIC Slot 1:
Serial number 35463147 Part number 800-06724-03
Connector type PCI
0x20: 01 30 01 00 02 1D 1F EB 50 1A 44 03 00 00 00 00
0x30: 58 00 00 00 06 11 28 00 FF FF FF FF FF FF FF FF
Both of your WIC cards are shown in the command, however
There is a small catch... To have your cards be visible in your running config, or sh int brie, you need to define the card type with some sort of config like this
"card type e1 4 0" (E1 or T1, based on the make, and your locality)
Usually, without this command, you can't even define the controllers.
Again, please start another thread (in case this doesn't solve your problem) in other forum, may be "Routing/Switching" as this forum is specifically for MARS discussion only.
