IDSM and blocking
z.kypry
I update my IDSM to version 3.0(2) S6 and add it into CSPM v2.3.3i with S11. But when I try to block host I obtain the message
The status of blocking IP address 192.168.65.40 for 1440 minutes on host "m3c-ids" is:
Error: The command failed
The IDSM has IP address 192.168.64.10
cat6506-msfc#sh users
Line User Host(s) Idle Location
1 vty 0 idle 00:00:16 192.168.64.10
* 2 vty 1 kypry idle 00:00:00 127.0.0.11
Interface User Mode Idle Peer Address
cat6506-msfc#sh access-lists
Extended IP access list IDS_vlan65_in_0
permit ip any any (71290 matches)
cat6506-msfc#
Why the command is failed and IDSM doesn't change the acl to block a host?
What is wrong in my configuration?
stleary
The problem might be in the IDSM shunning configuration.
Check to see if you have set 192.168.65.40 as a never shun address?
Or have you configured a never shun network that includes this address?
