ip binding to ethernet
de
hello,
im implementing site 2 site vpn. have configured nat on the main office server and am giving the fileserver static ip. the ip that is allocated is binding to ethernet port along with its hard coded ip.so ethernet has two ip's. if i change the ip of the fileserver ethernet picks it up still. could it possibly be nat.
many thanks
logging rate-limit console 10 except errors
enable secret 5 $1$d6OJ$JU.yzY/g6lGebq0i.gD5H0
username ********* password 7 0200014F020F172456
memory-size iomem 25
ip subnet-zero
no ip source-route
no ip finger
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.254
ip dhcp excluded-address 192.168.1.3
ip dhcp excluded-address 192.168.1.4
ip dhcp excluded-address 192.168.1.5
ip dhcp excluded-address 192.168.1.6
ip dhcp excluded-address 192.168.1.7
ip dhcp excluded-address 192.168.1.8
ip dhcp excluded-address 192.168.1.9
ip dhcp pool *********
network 192.168.1.0 255.255.255.0
dns-server 158.43.240.4 158.43.240.3
default-router 192.168.1.254
no ip dhcp-client network-discovery
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key ******** address 52.164.35.118
crypto ipsec transform-set strong esp-3des esp-sha-hmac
crypto map vpn 10 ipsec-isakmp
set peer 52.164.35.118
set transform-set strong
match address 101
interface Loopback0
ip address 10.1.1.1 255.255.255.0
interface ATM0
no ip address
ip nat outside
atm vc-per-vp 256
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
no fair-queue
crypto map vpn
interface FastEthernet0
ip address 192.168.1.254 255.255.255.0
ip nat inside
speed auto
no cdp enable
interface Dialer0
ip address 52.164.35.126 255.255.255.248
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap callin
ppp chap hostname *********
ppp chap password 7 121F00031B02140130
crypto map vpn
ip nat pool vpn 52.164.35.121 52.164.35.121 prefix-length 29
ip nat inside source route-map nonat pool vpn overload
ip nat inside source static 192.168.1.2 52.164.35.122
ip nat outside source static 52.164.35.122 192.168.1.2
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
access-list 10 deny 192.168.1.2
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 101 permit ip host 52.164.35.122 host 52.164.35.113
access-list 150 permit ip 52.164.35.112 0.0.0.7 52.164.35.120 0.0.0.7
access-list 150 permit tcp any any established
no cdp run
route-map static permit 10
match ip address 150
set ip next-hop 10.1.1.2
route-map nonat permit 15
match ip address 10
line con 0
password 7 045219561E34495A01
login
transport input none
line aux 0
password 7 020F160B1A130A3544
login
line vty 0 4
login
end
cjacinto
I don't think you need this line:
Do you really want to do the IPSec tunnel based on the public ip address?
Cause you could do it on the internal addr of 192.168.1.2.
See similar sample config on:
http://www.cisco.com/warp/customer/707/static.html
You have to use policy routing to bypass the ipsec traffic being nat'ed.
