ip verify reverse-path command
travis-dennis_2
Level 11
Level 11
Can anyone give me some feedback on using the ip verify reverse-path command? Any known problems, especially with an Exchange server on the inside, blocking good traffic, not doing what it is supposed to do etc. etc.
Thanks in advance
rrbleeker
Level 5
Level 5
The Ip verify reverse-path command checks the source IP address of a received packet. If a packet destined for the source address would use the same interface as it received the packet on, it is considered valid. In a simple environment (the Firewall is the only way out) you should not expect any problems using this feature. Its purpose is to prevent IP spoofing.
Thanks for your feedback!
