Is SSL tough enough ?
c.shults
I'm sorting out remote access, through the Internet, for some of our Thin Clients and I'm wondering if I need much stronger encryption then SSL. I know its a bad idea but I can't think why.
jbohla
It really depends... firstly, if other encryption standards are supported and secondly on the level of security that is required. For example, Cisco E-Mail Manager is a Web-based, thin client solution, written in Java. Clients log in to CeM, and perform all functions, through their Web browsers. CeM doesn't handle encryption internally. Instead, it uses Secure Socket Layer (SSL) encryption support to all inbound and outbound communication. So, i guess, SSL is the only option if you are working with CeM. Of late though, progress has been made on access security using a number of different encryption-based technologies such as S-HTTP and X.509 Certificate Authorities.
nimittj
Yes 128 bit SSL now supported is pretty strong, unless you are transmitting extremly confidential stuff.
You can learn more about SSL at http://wp.netscape.com/eng/ssl3/
Source code for implemeting SSL is available at http://www.openssl.org
Stronger encryption can be had by using Public Key Infrastructure (PKI) more info can be had at http://www.entrust.com
Let me know if you require more info.
