ISAKMP: reserved not zero on payload 5!
markfen
I'm trying to establish a VPN with a PIX 515E using a Solaris 9
client.
The Solaris client is the initiator, The phase 1 IKE
exchange fails , the PIX does not like something
in the 5th packet in main mode. I got this from
the PIX debug log:
What does this mean ?
This is using native Solaris IPsec, preshared keys.
Cisco software version 6.1
afakhan
Level 4
Level 4
It means you need to re-enter preshared keys on the two sides.
Thx
Afaq
Hello Afaq,
This helped - actually the problem was Solaris uses preshared
keys in hex, Cisco uses ASCII :-)
I still get this message, but the negotiation gets further this time
despite the above error. The failure point is now in phase 2:
IPSEC(validate_transform_proposal): invalid local address x.x.x.x
Where x.x.x.x is the IP address of the PIX
I saw an article on your website which mentioned this - I need
to use:
crypto map map-name local-address interface-id
The documentation does not cover this command ( unless
I overlooked it )
Thanks again.
This is usually a fairly generic error when it comes to the PIX. The "local-address" command you're referring to is an IOS router command, not a PIX command, so that's why you're not seeing it.
Check your transforms, ACL's, etc on both sides, make sure they match properly.
