ISAKMP SA negotiation fails with Watchguard Firebox II
awoodruff
For the past couple weeks, our IPSec tunnel has dropped intermittently with the following debug results below. The IPsec tunnel terminates with a Watchguard Firebox II.
Am I interpreting this correctly? It appears that the Watchguard is trying to negotiate a SA using DES, SHA, and a pre-share key, but eventually times out. The actual policy is for 3DES, MD5, and a pre-shared key. However, when we re-boot the PIX, the two devices connect. Is this a bug problem with the PIX OS?
ISAKMP (0): Checking ISAKMP transform 1 against priority 10 policy
ISAKMP: encryption DES-CBC
ISAKMP: hash SHA
ISAKMP: auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
ISAKMP: default group 1
ISAKMP (0): atts are not acceptable. Next payload is 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 65535 policy
ISAKMP: hash SHA
ISAKMP (0): no offers accepted!
ISAKMP (0): SA not acceptable!
return status is IKMP_ERR_TRANS
ISAKMP (0): deleting SA: src 206.142.126.125, dst 67.39.58.130
ISADB: reaper checking SA 0x80d0cfb8, conn_id = 0 DELETE IT!
afakhan
Level 4
Level 4
it seems that watchguard box is sending :
DES-SHA-Group1-Preshared
and your policy#10 on pix doesn't have that, if you do have that policy, pix should negotiate it, otherwise try loading V6.3.1, if that doesn't help, open up a TAC case to file a possible bug.
Thx
Afaq
