Layer 2 encryption over GigabitEthernet
lcolimoro
We are looking for a solution to avoid VPNs to encrypt data between HQ and Bldgs (point-to-multipoint) Gigabit fiber(untrusted media).
Is there any cisco's product providing layer2 encryption over Giga fiber?
The HQ has a 6509s and remote bldgs have mixed of 3750s,4500s in trunks.
andrew.burns
Level 7
Level 7
If you go with Cisco you'll be limited to VPN's but there are plenty of 3rd party devices which are available, such as the following:
http://www.thales-esecurity.com/productsservices/DC2K_GigE.shtml
Andrew.
You can do it with Cisco switches. You don't need Cisco ASA for that.
The feature you're looking for is called "MACSec". Here' s a link http://www.cisco.com/en/US/docs/switches/lan/trustsec/configuration/guide/config.html
Please rate if it helps.
