log message problem
walidboudich
Level 2
Level 2
hello,
my PIX had reported the following message:
Dec 22 08:15:11 192.168.47.254 %PIX-6-106015: Deny TCP (no connection) from 10.23.18.102/1035 to 192.168.50.214/80 flags RST on interface outside
i can't understand the (no connection) message
can you give me some help
thanks
phil.benn
Community Member
hi,
i would expect that it's because your source host (10.23.18.102) is trying to send a reset (RST) to the host the other side of the pix. if the pix doesn't have a connection listed in its state table, it won't expect the RST and will thus report 'no connection'. it's probably nothing to worry about, i notice the d-port is 80, web browsers sometimes send RSTs back to webservers to close connections quickly; instead of tearing them down properly.
