07-07-2009 07:01 AM - edited 03-09-2019 10:25 PM
I have 2000 users and i want to use the same login and password for CAA clean access agent for all of them.
it is possible to do that without problem?
07-07-2009 07:59 AM
why would you want to do that?
if you want them all to have the same profile applied then just set a default profile.
07-07-2009 08:13 AM
if you really want to do that, just disable SSO and have all 2000 users manually type in the username and password.
07-08-2009 01:00 AM
I want to verify the conformity of the client poste without authentication or at least one shared login and password of all users.
I need the authentication of CAA the be transparant for final user.
07-08-2009 05:49 AM
you can see which profile a user login belongs to once they log in through the GUI..or by using the Test function in the GUI as well.
