Mars and NAC 4.8
a.chernomazov
Hello, i am deploying CS-MARS and i have i problem, i cant add Cisco Network Access Control in the MARS to the controleld devices
There is just 4.1 versions.
Is it support 4.8?
Thanks in advance
A.Black
Farrukh Haroon
Hello Alexander
Since MARS is going away in a while, you won't find that many device updates,even the latest release does not support NAC 4.8.x (officially).
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.1/compatibility/local_controller/dtlc6x.html
However you can always add a NAC  4.8.x box as whatever is supported in the GUI and MARS would work in backwards compatible mode ignoring the  log messages introducted in the newer releases.
Farrukh
