MARS Database problem
jms112080
Level 3
Level 3
MARS box does not seem to be logging anything to the local database. Logging to the archive server seems to be working fine, but I get no results when I query anything (syslogs,events,etc) within the last 24 hours. Any ideas what to check or what might cause this?
wong34539
Level 11
Level 11
To view the appliance's log files or to change their levels or source, navigate to Admin > System Maintenance > View Log Files
You can view the appliance's backend logs either by selecting a number of days, hours, and minutes or you can view logs by selecting a start and ending date and time. You can select the levels of logs that you want. Your choices are: All, Fatal, Error, Warn, Info, and Debug.
You can also choose the source of the files that you want to view. Select either Backend or GUI.
