03-14-2002 04:01 AM - edited 03-08-2019 10:03 PM
Hi all,
Can anyone give me some advice on the following please.
If I have: server -> PIX -> router
and I want to allow snmp from the router back to the server I believe I need to create a static from the ip of the router to the ip of the server?
ie:
static (inside,outside) Router IP IP of Server netmask 255.255.255.255 0 0
then
conduit permit udp host Server IP eq snmp host Router IP
conduit permit udp host Server IP eq snmptrap host Router IP
if this is correct then am I also able to create another static using the servers ip address for incoming smtp traffic using another address??
If i've forgotten anything important please say.
thanks for your time
Andy
03-14-2002 06:31 AM
1. You should not translate the Router IP address to the server's address. this is defnitely not going to work as the server's translated address has to be unique and cannot be the same as that of the Router IP address (I am assuming by router ip address, you are refering to the ethernet interface of the router.
2. SMTP: You have to statically translate the server's ip address to the corresponding MX entry of the SMTP server and then write conduit statements to allow port 25.
3. I have never done this but this is my 2 cents on the snmp:
From the IP persepective, both the IP domains (the internal of the router is in the same IP domain as that of the external of firewall) are known to the firewall. Hence just add the conduit statements - it should just work fine.
Best Regards / Sampath
New York, NY.
03-16-2002 09:16 AM
Yes, your setup should work, but the static command should be as follows:
static (inside,outside) Server global ip IP of Server netmask 255.255.255.255 0 0
where "server global ip" is an ip address of your choice that will reside in the "outside" network/subnet (the ip address will be created automatically by the PIX outside interface and will have the same mac address). If the PIX outside interface and the router are on the same network/subnet, then the global ip address should be in the same subnet as well. If however the router is on a remote subnet/network, you need to add a static route to it in the PIX.
As for the conduits, use the "server global ip" instead of the "Server IP (local)"
Mustafa
