04-14-2003 12:55 PM - edited 03-09-2019 02:54 AM
I'm using multiple 1710's in my network. Remote sites use the AUX port to call back Head office 1710 modem if their connection goes down. The problem with this is only one connection is allowed. The rest of the remote sites will get a busy signal.
I would like to have some redundany for the remote sites, without spending money on more hardware. I have a fiber connection to Head Office, it's very stable and I'm not worried about redundancy here. Is it possible to use an Internet dialup account and establish a vpn connection to Head Office? Can I still use a GRE Tunnel? I guess you can't use an IP since it is not known, is it possible to use a MAC address instead? How do I go about getting this setup?
Somebody please help!!
Jesal
Below is my HEADOFFICE and one of REMOTE configs.
"HEADOFFICE CONFIG"
version 12.2
service timestamps log datetime
service password-encryption
hostname HEADOFFICE
logging buffered 20000 debugging
logging console notifications
aaa new-model
aaa authentication login default local
aaa authentication login NO_AUTH none
aaa authentication ppp default local
aaa authorization network grouplist local
aaa session-id common
enable secret 5 ******
username REMOTE1 password 7 ******
memory-size iomem 25
ip subnet-zero
no ip source-route
no ip domain lookup
ip host loop 2005 192.168.50.1
ip inspect name fw1 tcp
ip inspect name fw1 udp
ip inspect name fw1 ftp
ip audit notify log
ip audit po max-events 100
modemcap entry MYMODEM:MSC=&F1S0=1
crypto isakmp policy 1
authentication pre-share
crypto isakmp policy 2
hash md5
crypto isakmp key ****** address 209.115.*.*
crypto ipsec transform-set ts1 esp-des esp-md5-hmac
crypto map cfmap local-address Ethernet0
crypto map cfmap 40 ipsec-isakmp
set peer 209.115.*.*
set transform-set ts1
match address 104
interface Loopback0
ip address 192.168.50.1 255.255.255.0
interface Tunnel4
description GRE tunnel to REMOTE1
bandwidth 1000
ip address 192.168.104.1 255.255.255.0
ip mtu 1420
no ip route-cache
no ip mroute-cache
tunnel source Ethernet0
tunnel destination 209.115.251.253
crypto map cfmap
interface Ethernet0
description Telus fibre to Internet
ip address 216.123.*.* 255.255.255.248
ip access-group 120 in
ip nat outside
no ip route-cache
no ip mroute-cache
half-duplex
no cdp enable
crypto map cfmap
interface FastEthernet0
ip address 192.168.0.201 255.255.255.0
ip nat inside
ip inspect fw1 in
no ip route-cache
ip policy route-map nonat
no ip mroute-cache
speed auto
half-duplex
no cdp enable
interface Async5
ip unnumbered Loopback0
encapsulation ppp
load-interval 30
dialer in-band
dialer idle-timeout 900
dialer map ip 192.168.54.1 name REMOTE1 broadcast
dialer-group 1
async default routing
async mode interactive
no peer default ip address
ppp authentication chap
router ospf 5
log-adjacency-changes
network 192.168.104.0 0.0.0.255 area 0
access-list 104 remark Define crypto traffic on GRE tunnel to REMOTE1
access-list 104 permit gre host 216.123.*.* host 209.115.*.*
dialer-list 1 protocol ip permit
no cdp run
route-map nat1 permit 10
match ip address 151
route-map nonat permit 10
match ip address 150
set ip next-hop 192.168.50.2
snmp-server community public RW
snmp-server enable traps tty
line con 0
login authentication NO_AUTH
line aux 0
modem InOut
modem autoconfigure type MYMODEM
transport input all
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
exec-timeout 30 0
password 7 *******
length 0
end
"REMOTE1 CONFIG"
version 12.2
hostname REMOTE1
aaa new-model
username HEADOFFICE password 7 ******
ip subnet-zero
no ip source-route
no ip domain lookup
ip host loop 2005 192.168.54.1
ip dhcp excluded-address 192.168.4.1 192.168.4.19
ip dhcp excluded-address 192.168.4.100 192.168.4.254
ip dhcp pool LAN
network 192.168.4.0 255.255.255.0
default-router 192.168.4.200
dns-server 192.168.0.8
netbios-name-server 192.168.0.12
domain-name DOMAIN
ip audit notify log
chat-script Dialout ABORT ERROR ABORT BUSY "" "AT" OK "ATDT\T" TIMEOUT 45 CONNECT \c
modemcap entry MYMODEM:FD=&F1:AA=s0=1:MSC=&F1S0=1
hash md5
crypto isakmp key ten4bigfella address 216.123.*.*
crypto map cfmap 10 ipsec-isakmp
set peer 216.123.*.*
match address 100
interface Loopback0
ip address 192.168.54.1 255.255.255.0
interface Tunnel4
description GRE tunnel to HEADOFFICE
bandwidth 1000
ip address 192.168.104.2 255.255.255.0
ip mtu 1420
no ip route-cache
no ip mroute-cache
tunnel destination 216.123.*.*
crypto map cfmap
interface Ethernet0
description Internet connection
ip address 209.115.*.* 255.255.255.192
ip nat outside
no ip route-cache
no ip mroute-cache
half-duplex
no cdp enable
crypto map cfmap
ip address 192.168.4.200 255.255.255.0
ip nat inside
ip inspect fw1 in
no ip route-cache
no ip mroute-cache
no keepalive
speed auto
half-duplex
no cdp enable
interface Async5
encapsulation ppp
dialer in-band
dialer idle-timeout 300
dialer map ip 192.168.50.1 name HEADOFFICE broadcast 287****
dialer map ip 192.168.0.0 name HEADOFFICE broadcast 287****
dialer watch-group 8
dialer-group 1
router ospf 5
network 192.168.4.0 0.0.0.255 area 0
network 192.168.54.0 0.0.0.255 area 0
ip nat inside source route-map nat1 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 209.115.*.*
no ip http server
ip pim bidir-enable
access-list 100 remark Define crypto GRE traffic to HEADOFFICE
access-list 100 permit gre host 209.115.*.* host 216.123.*.*
dialer watch-list 8 ip 192.168.0.0 255.255.255.0
dialer watch-list 8 delay disconnect 15
dialer-list 1 protocol ip list 130
no cdp run
set ip next-hop 192.168.54.2
snmp-server community public RO
line con 0
line aux 0
script dialer Dialout
modem InOut
transport input all
autoselect ppp
stopbits 1
speed 115200
line vty 0 4
exec-timeout 30 0
password 7 ******
length 0
end
04-17-2003 06:18 AM
You should be able to use a dial up account to connect to the Head office via VPN. This URL should assist you with the configuration. http://www.cisco.com/univercd/cc/td/doc/product/core/7100/swcg/6342ch4.htm#1035840
04-21-2003 09:45 AM
Thanks, this should give me a few ideas to get started.
Thank you.
