No response from Enterprise LAN...
optimhom97
I have a 1721. I've tried to configure a VPN access with Cisco Client to my routeur. The tunnel established good. I receive an IP.But I can't ping anything except my cisco LAN interfaces. Computer from Enterprise see my ping and answer but nothing arrive to my computer(saw it with ethereal). My conf is attached (my client log too). If someone can really help me...
shijogeorge
This looks like a routing problem. Try adding the following command.
crypto dynamic-map dynmap 10
reverse-route
Shijo George.
Hi shijogeorge, I've tried without success...
andrew100
Hello - Sounds like Routing. For starters... Is your Default Gateway on the LAN that of the VPN Router?
My VPN serveur is a 1700 which is my LAN default routeur. Everything is routed by dialer 1.
I shut my hardware VPN Module. No it works I can ping everything but it s so long ! If I try to download a file from a computer, it doesn t work I see every files, but I have an error message which says that the file doesn t exist anymore...
If you have an idea let me know...
