NTP and Ciscoworks VMS
melangnghe
Does anyone know if there is a way to allow Ciscoworks VMS 1.2.3 to connect to NTP server?
dblairii
There is not a way to connect VMS itself to NTP, per se, but you can always time sync your OS (which VMS is running on top of) with NTP. Additionally, you can configure your IDS sensors to use NTP.
Hope that helps.
