One Way Communication - ACL
SnarkyPrime
Hello
I tried to do an ACL, but it did not really work, so i want to ask for your help guys.
My idea was an one way communication. I wanted the PC3 (blue) to be a supervisor pc, which can access to every other pc, but nobody can (gain?) access to PC3.
I tried this:
access-list 100 deny ip any host *blue pc IP-address*
access-list 100 permit ip host *blue pc IP-address* any
but it did not work
access-list 100 permit icmp any host *ip address* echo-reply
access-list 100 deny icmp any host *ip address* echo
this make only echo-reply accept and echo deny
11 Replies 11
 Where did you applied the ACL ?  Can you share you project?  zip it first.
i applied everywhere, to test it, but only one at the time, i dont know where should i apply, because these are sub-interfaces
allow only the ping-reply from any to PC3
this make all PC can reply tp ping from PC3 but can not ping PC3
make the ACL of ping-reply direction IN <<- apply it to router.
how can i do that?
access-list 100 deny icmp any host *ip address* echo?
thank you, and where should i apply the acl if there are only sub interfaces?
but are all host in same subnet ?
this is how it looks like
the supervisor pc is in the 0/0.30
then apply the ACL direction IN under the subinteface f0/0.10 and f0/0.20
it works, thank you very much!
You are so so welcome
