passive ftp not working on 2811
palvin_225
Hello all,
We recently replaced a pix 501 with a cisco 2811 in our head office. We have created and applied access lists and everything is working fine now except our passive ftp. Some of our clients who try to access our as400 via ftp can connect but cannot copy or view any listings in the directory. We are using the following lines in our access-list to control incoming ftp access.
access-list 111 permit tcp any gt 1023 host xxx.xx.xx.xxx eq ftp
access-list 111 permit tcp any gt 1023 host xxx.xx.xx.xxx gt 1023 established log
Please suggest.
Thanks in advance.
jkell
For "passive" FTP, the connections will NOT be established as the client connects back to the server, source and destination ports > 1023. You cannot key these connections with "established".
Most FTP servers will allow you to specify a range of ports to use for incoming passive data connections. In vsftpd for example you can set "pasv_min_port" and "pasv_max_port" in /etc/vsftpd/vsftpd.conf to specify a range of ports to offer for passive data connections. You can then alter your second access-list permit to specify:
permit tcp any gt 1023 host a.b.c.d range min max
where "min" and "max" are the ports specified above.
If your server doesn't allow you to set the data port range, you will have to permit any gt 1023 (which is a large, gaping hole).
victory_cm
Hope FTP works with port 21 for authentication and port 20 for data transfer.
Hence please add the following ACL
access-list 111 permit tcp any gt 1023 host xxx.xx.xx.xxx eq ftp-data(port 20) and try.
Thanks...
We got our passive FTP working. We had to add CBAC in order for passive FTP to work on IOS version equipped with security. We added the following lines to our config:
ip inspect audit-trail
ip inspect name FTPRULENAME ftp alert on audit-trail on timeout 3600
Then in our access list on our external interface, we added these lines
access-list 101 permit tcp any gt 1023 host xxx.xx.xxx.xx eq ftp
access-list 101 permit tcp any gt 1023 host xxx.xx.xxx.xx gt 1023 established log
Now our passive FTP is working no problems.
