ping from one interface with 10.0.x.x addresses to others
Jim.Kiddoo
I have a problem with machines on other interfaces with routable addresses being able to see machines on another interface with n0n-routable addresses. They cna't ping the non routable ones until the non-routable ones ping them and then they can ping 10.0.0.x addresses. I have them all using the same address when they travers the interfaces. Is there anything i can do accept force the clients to ping before doing anything? I am trying to move machines to a new domain and it doesn't work until they ping the AD domain controller. It is a Pix 515e unrestricted running 6.2(2)
Jim Kiddoo
mostiguy
Level 6
Level 6
There are a variety of ways to create translation slots through a pix, which is what allows traffic to pass from less to more secure interfaces. nat 0 can do this, but can cause the behaviour you see, as those slots created as a result are only temporary. The static command will create permanent slots for less secure interfaces to talke to higher security ones (so long as access-lists or conduit commands permit access though).
You probably need to add a static command for the higher security interface ip addresses.
Makes sense, do i have to create them for each device or can i do it for the interface.
Sincerely
Jim Kiddoo
