07-25-2003 11:07 AM - edited 03-09-2019 04:12 AM
Both the Toshiba and Dell PPC 2003 devices cannot connect to our VPN3060 using PPTP. We can ping the interface, but not connect. The log shows no attempt at a new connection. Anyone had success with the new WinCE? Or knows what is going on?
Tom Zeller
Indiana University
812-855-6214
07-28-2003 07:47 AM
I did get this client to connect. However it suffers from the same shortcomings as the earlier version. You can build a tunnel and ping through it indefinitely, but when you try to use any of the Microsoft applications such as Pocket IE or Outlook, the connection is dropped from the client side. 3rd party browsers are available to solve the web problem. - Tom Zeller, zeller@indiana.edu
08-07-2003 08:36 AM
Another update - The 2003 PPC client doesn't seem to do encryption. It will only connect if the "require encryption" box on the base group is UNchecked.
-Tom Zeller
