02-23-2004 07:29 PM - edited 03-09-2019 06:31 AM
We have a problem containing port scans originating from our dial-up pool clients...Can someone advise us on what measures to take. We plan to block the whole IP block but don't know which ports to block so as not to affect the service.
02-24-2004 08:44 AM
there is no good method - any decent port scanner has variety of options to tweak the source port as well as its randomness for port scanning. Could you insert an IDS into the mix - maybe it would be able to correlate the behaviour, and you could craft an auto shut down solution to kill their ip's connectivity.
Are you an ISP, or are you providing a limited subset of functionality?
02-24-2004 09:34 AM
You could also apply command - icmp deny any outside, this will make your inside network invisible to the outside scanners, go to http://www.grc.com and run 'shields up' before applying the above command and see if there are any open ports and then apply the above command and run 'shields up' and check the results.
Hope this helps a little.
Jay
