PPTP, NAT, and 7200
droberts
I have a 7200 with an internal Linux vpn pptp server. I would like to run NAT on the 7200 but have had bad luck running NAT w/ VPN in the past because NAT tampers with VPN packets.
1.) Is there an IOS, config that will make this work today
2.) I've heard the 7200 might run pptp services itself. Is there an IOS, config to make this work and would it be recommended over the internal Linux box? (I've heard poor encryption performance w/ 7200).
a-vazquez
Level 6
Level 6
I don’t think PPTP works with NAT. IPsec should be fine.
