privilege level to allow interface FastEthernet but not GigabitEthernet
franklinwong
Any way to allow access to FastEthernet interfaces but not GigabitEthernet interfaces using the privilege level command?
John Blakley
You would have to assign all of the interfaces manually for the privilege level that you want to allow access to. You could also assign a view if your device supports it.
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi John,
Thanks for your reply.
I applied the command "privilege configure level 10 interface FastEthernet0/1" but the user can also get into other interfaces. I discovered that whenever there is "privilege configure level 10 interface" in the command, no matter what follows, the user can access all interfaces, including FE, GE, Vlan, etc.
Any idea?
