Problem browse computer in MS domain network
lathian
Just wondering if anyone has had the same problem. I have VPN 3015 ver 3.12 and VPN Client ver 3.6 using IPSEC. When I connect, I can browse and ping all computer in LAN by name and IP. The problem started when I rebooted vpn box. I still can ping by name and IP, but I am not able to browse or map drive on any computer in the LAN. All the setting keep the same before and after the problem start.
Thanks in advance
drolemc
Level 6
Level 6
A problem easily solved as shown in http://www.cisco.com/warp/customer/471/vpn-net-hood.html#map. Best of luck.
