Showing results forĀ
Search instead forĀ
Did you mean:Ā
Problem With AnyConnect Client download with CSD
utpal.singh
I am using ASA 5550 version 8.2.
My problem is using CDS (Cisco Secure Desktop) along with AnyConnect Clinet.
Problem Summary: The moment i enable  CSD, AnyConnect Client download for first time user fails with error "Web Download failed".
Observation: If CSD is disabled SSL VPN client download happed and works fine.
                     If CSD is enabled after SSL VPN client is already available on remote desktop it works fine. However, with CSD enabled SSL clinet
                     download doesnt happens.
CSD version used : csd_3.4.1108.pkg
SSL client version : anyconnect-win-2.3.0254-k9.pkg
Please help if
anujbtewari
Dear Utpal,
I know it's bit old post but i hope you are able to fix this issue.
Could you please post here how you fix this issue ??
Thanks in Advance.
