I've tryed to import an xml file to CSPM (This xml file was generated from Config Import Tool) but an exception occurs, which is :
"An application error has occured
and an application error log was generated
Cfmi.exe
Exception access violation 0xc0000005 adress 0x118c5930
and in the log file there was :
"Warning:CSPM server and management address not available. Setting it to 0 for device->PIXTest"
but I can't modify anything because CSPM crashes after this warning!!!
What can I do to avoid this error?
Thank you in advance.
