02-23-2004 09:23 AM - edited 03-09-2019 06:31 AM
I am trying to convert my VPN infrastructure from a model where the remote routers terminate their IPSec tunnels on a VPN concentrator and static routing is used for all sites, to a model where we employ GRE tunnels and enable EIGRP over those tunnels for spoke-to-spoke communications through the hub.
I have three routers setup in a test lab and have configured one of them as a moc hub and the other two as spokes. Testing looks like it works, but if I do a 'show crypto engine conn active' on the hub router, it shows that both remote routers have terminated on a one of the tunnel interfaces instead of each tunnel terminating on its own.
Any assistance and/or feedback on design would be greatly appreciated.
Thank you,
Justin Loucks
Here are excerpts of the configs of each router...
Hub router config
Router-A#show config
Using 1617 out of 29688 bytes
version 12.3
crypto isakmp policy 1
authentication pre-share
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set 3des esp-3des esp-md5-hmac
mode transport
crypto map vpn 1 ipsec-isakmp
set peer 10.10.227.10
set transform-set 3des
match address 101
crypto map vpn 2 ipsec-isakmp
set peer 10.10.227.14
match address 102
interface Tunnel1
ip address 172.31.1.1 255.255.255.0
tunnel source Ethernet0
tunnel destination 10.10.227.10
crypto map vpn
interface Tunnel2
ip address 172.31.2.1 255.255.255.0
tunnel destination 10.10.227.14
crypto map vpn
interface Ethernet0
description tunnel endpoint
ip address 10.10.227.18 255.255.255.252
half-duplex
crypto map vpn
interface FastEthernet0
description inside
ip address 192.168.0.1 255.255.255.0
speed auto
router eigrp 10
network 172.16.0.0
network 172.31.0.0
network 192.168.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
no ip http secure-server
access-list 101 permit gre host 10.10.227.18 host 10.10.227.10
access-list 102 permit gre host 10.10.227.18 host 10.10.227.14
end
Spoke router1
Router-B#show config
Using 1283 out of 29688 bytes
mode transport
set peer 10.10.227.18
match address 111
interface Tunnel0
ip address 172.31.1.2 255.255.255.0
no keepalive
tunnel destination 10.10.227.18
crypto map vpn
interface Ethernet0
description outside
ip address 10.10.227.10 255.255.255.252
ip nat outside
half-duplex
crypto map vpn
description inside
ip address 192.168.1.1 255.255.255.128
ip nat inside
speed auto
router eigrp 10
network 172.31.0.0
network 192.168.1.0
auto-summary
no eigrp log-neighbor-changes
ip classless
no ip http server
ip pim bidir-enable
access-list 111 permit gre host 10.10.227.10 host 10.10.227.18
end
Spoke router2
Router-C#show config
Using 1281 out of 29688 bytes
mode transport
match address 102
interface Tunnel0
ip address 172.31.2.2 255.255.255.0
no keepalive
crypto map vpn
interface Ethernet0
description outside
ip address 10.10.227.14 255.255.255.252
ip nat outside
half-duplex
crypto map vpn
description inside
ip address 192.168.212.1 255.255.255.128
ip nat inside
speed auto
router eigrp 10
network 172.31.0.0
network 192.168.0.0
auto-summary
ip classless
no ip http server
ip pim bidir-enable
access-list 102 permit gre host 10.10.227.14 host 10.10.227.18
end
02-23-2004 02:48 PM
This is just a cosmetic bug with the output of the command. With your configuration the tunnels will be terminating correctly on the two different hub tunnel interfaces, it's just the command output that's wrong (it's been that way for a while actually, I never take any notice of the interface that shows up in this command output).
FYI, if you're just starting to implement GRE/IPSec, you might want to look at Dynamic Multipoint VPN (DMVPN). It's GRE/IPSec, but makes the config on the hub small and allows for your spokes to have dynamic IP addresses, via PPPoE/DHCP on ADSL/Cable for example. Once you set the hub up you never need to change it when you add additional spokes, unlike standard GRE/IPSec where the hub config gets larger as each spoke is added.
You can read all you'll ever want to know about it here:
02-24-2004 04:43 AM
In regards to the DMVPN, I have always worried about setting up a hub router to accept connections from any IP address. Am I just paranoid here or is there a security risk in doing this? Just for clarification, I did modify the configurations in my original post to show private IPs, but my end project will be running over public space.
03-11-2004 05:10 AM
Small but nice improvement: from IOS 12.3(13)T you only need to apply "crypto map vpn" to physical intefface. I tihnk this feature included to IOS 12.3.
