06-19-2011 08:51 AM - edited 03-09-2019 11:34 PM
Hi, I'm starting to train for my certification and have being following any posible explanation on how to configure ssh for a cisco 871w router, and there's no way I can connect. I've used TeraTerm Version 3.13 and 4.69 and it keeps asking me for the password wich I'm entering correct.
This is really frustrating since everywhere i look for answers i noticed that it should be something simple to do and still is not working for me.
Anyway this is my runing config if someone can give me a hand I'd really appreciate it
Current configuration : 1317 bytes
version 12.4
service config
no service pad
hostname labrouter
boot-start-marker
boot-end-marker
enable secret 5 $1$AnLl$H5XfrfdN5L6bogmtdGW.Y1
no aaa new-model
dot11 syslog
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip domain name house.com
username tripi22 password 0 ld30dzy7
archive
log config
hidekeys
ip ssh version 2
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
duplex auto
speed auto
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
banner motd ^C
NO JODER
******************************************************************************^C
line con 0
password 123
login
no modem enable
line aux 0
line vty 0 4
password 123
login
transport input telnet ssh
scheduler max-task-time 5000
end
version 12.4
service config
no service pad
hostname labrouter
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
archive
log config
hidekeys
ip ssh version 2
ip address dhcp
duplex auto
speed auto
no ip address
shutdown
54.0
station-role root
interface Vlan1
no ip http server
control-plane
banner motd ^C
NO JODER
line con 0
password 123
login
no modem enable
line aux 0
line vty 0 4
password 123
login
end
Solved! Go to Solution.
06-19-2011 06:38 PM
Can you try changing the command "login" to "login local" under the vty lines?
Wen
06-19-2011 11:59 AM
Ariel: What password are you trying to login into it?
Jatin
06-19-2011 12:02 PM
i'm tryig to login to user tripi22 password ld30dzy7
I even tryied with secure crt and same error authentication failed.
This is driving me crazy
06-19-2011 06:38 PM
Wen
06-19-2011 06:49 PM
that's exactly what it was, thanks a lot and forgive mi ignorance
