Qos for VPNs
nd
When you configure the command 'qos pre-classify' are the DSCP bits copied to the tunnel header in addition to the TOS bits?
beth-martin
Level 5
Level 5
I didn’t find anything published so you’ll probably have to run a packet trace and take a look at the header. Is there a certain problem you are trying to find?
daide
What Cisco VPN products support QoS?
The only one that I can see for definite is the Cisco 7100 router? What about the PIX series, VPN concentrators & the IOS F/W Feature set? Any ideas?
