Question about CSIDS-313-engrel2.tar.Z
mhicks
Two Questions....
In the readme file at step 5 the command is tar xvf CSIDS-313-eng.tar.
Is the command typed wrong because the file name does not match the file name in the previous steps.
When I do the command tar xvf CSIDS-323-engrel2.tar.Z I receive a directory checksum error. Why am I getting a checksum error?
pheuch
You missed the uncompress step before.
gzip -d CSIDS-323-engrel2.tar.Z (gives you CSIDS-323-engrel2.tar)
and after that
tar -xvf CSIDS-323-engrel2.tar
gbrother
The readme is incorrect for steps 4 and 5. The should read as follows:
4) uncompress CSIDS-313-engrel2.tar.Z
5) tar xvf CSIDS-313-engrel2.tar
The reason your tar received and error was because you need to uncompressed the file 1st.
I will talk to the owner of the file to get the README corrected.
dlac455
Is 3.1.3 still in early release? If so, any schedule yet for general release?
Currently this fix is only available as an engineering release. We have been discussing when it will be sent out as a general release but nothing has been decided as of yet.
