Radius server for lab work
Kevin Dorrell
Level 10
Level 10
I am studying Routing & Switching, but I also need to have a general understanding of the security features: AAA authentication, dot1x etc. It is probably the weakest link in my chain of knowledge because I have never used those
features.
I really need to play with the protocols in the lab to get a basic understanding of them. Is there some cut-down Radius server, preferably freeware running on a PC, that can be used for basic lab work? Can someone guide me through obtaining and installing it?
Kevin Dorrell
Luxembourg
5 Replies 5
Jon Marshall
Hi Kevin
You should be able to get an eval license for Cisco's Secure ACS that you could use in the lab. It is free for download on the Cisco site.
It does run out after 3 months so it depends on how long you need it for.
The other option is to use the Microsoft Radius server (IAS) which comes with the W2K Advanced server. I haven't used it so i can't really comment other than that.
Jon
Hi Jon,
Is that easy to set up, and does it run on a PC? I'm thinking in terms of my home lab, and running it on my old laptop, just tucked away in a corner somewhere.
Kevin Dorrell
Luxembourg
Kevin
I have run the ACS software on a laptop to eval it altho from memory i was running W2K server on the laptop. Is this possible for you to do ?
You need a login to Cisco web site but i'm assuming you have this ?
http://www.cisco.com/kobayashi/sw-center/sw-ciscosecure.shtml
Jon
OK, thanks Jon. I shall give it a go next lab session, and I shall let you know how I get on. Gotta get over the "fear of the unknown" factor first tho'.
Kevin Dorrell
Luxembourg
Kevin
No problem. Guarantee you will manage to lock yourself out of a switch/router at least once :).
Can't count the number of times i've done it.
Jon
