Redirection
rmwhite59
Level 2
Level 2
I have a new pix 501 setup and need to redirect dns, smtp, pop3, http, and ftp traffic from 24.xxx.xxx.61 to 192.168.1.4. The external gateway is 24.xxx.xxx.61 I have tried several thing but can't get it to work. Anyone have any suggestions?
tmoreo
Level 3
Level 3
Three quick things off the top.
1) Can you post the config
2) Port mapping is done on the external interface and not the external gateway. so give that a shot.
3) Try the gui. it often is forgiving and guides you through some configuration
pwicks
Level 3
Level 3
****** Application Layer Protection for HTTP, SMTP, POP3, FTP and DNS *******
fixup protocol http 80
fixup protocol ftp strict 21
fixup protocol dns maximum-length 512
fixup protocol smtp 25
******* Access List to Permit Outside Connections to Internal Servers ********
access-list outside-in permit tcp any host 24.xxx.xxx.61 eq www
access-list outside-in permit tcp any host 24.xxx.xxx.61 eq smtp
access-list outside-in permit tcp any host 24.xxx.xxx.61 eq pop3
access-list outside-in permit tcp any host 24.xxx.xxx.61 eq ftp
access-list outside-in permit tcp any host 24.xxx.xxx.61 eq domain
access-list outside-in permit udp any host 24.xxx.xxx.61 eq domain
******* Apply Access List to Outside Interface *******
access-group outside-in in interface outside
******* Translation for External to Internal IP *******
static (inside,outside) 24.xxx.xxx.61 1192.168.1.4 netmask 255.255.255.255 0 0
- This is for version 6.3(4) or above.
- Do not include the lines with the *********
- Make sure that you change tghe 24.xxx.xxx.61 references to the real external IP address
- If your mail server needs ESMTP commands (like Microsoft Exchange), do not use the SMTP fixup
Two more questions
1) Do you want to perform Port Redirection or a static NAT with filtering
Your config is for static NAT with filtering
Port redirection might look more like
static (inside,outside) tcp interface smtp 192.168.1.4 smtp netmask 255.255.255.255 0 0
no need for the access list.
2) What is the address of your external interface and is this your only ip or do you have multiple?
pwicks
Level 3
Level 3
You are correct. Since the poster asked for code for redirection, please see below:
****** Translation for Outgoing Traffic *******
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
******* Translation for External to Internal IP Using Port Redirection *******
static (inside,outside) tcp interface www 192.168.1.4 www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface pop3 192.168.1.4 pop3 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface domain 192.168.1.4 domain netmask 255.255.255.255 0 0
static (inside,outside) udp interface domain 192.168.1.4 domain netmask 255.255.255.255 0 0
