Remote Desktop Connection dropping
boschrexroth
I have a RDC connection into a remote server that is on a VPN tunnel between 2 pixes.
When I have this access-list in it does not drop.
access-list 111 extended permit ip 10.10.128.0 255.255.255.0 192.9.20.0 255.255.255.0
but when I tried to tighten my access-list to
access-list 111 extended permit ip host 10.10.128.183 192.9.20.0 255.255.255.0 so that only 1 host can access the remote network the connection drops every couple of minutes and then re-establishes itself.
Any ideas?
Thanks.
boschrexroth
Anyone have any ideas why this is happening?
Thanks.
cmcbride
Is access-list 111 used for the crypto map, or is it used for the ip access-group? If it's used for the crypto map, then did you change the access-list parameters on both sides of the tunnel?
