Remote VPDN to internal hosts without static translation
rsnider
Is it possible to make pptp or ipsec connections to inside hosts from the internet without static translation of the inside host addresses? I have a PIX515 with 6.1(1). What commands are required? I have working connections to hosts with static IP addresses.
j-block
Level 4
Level 4
No, you’ll have to have statics for any host you need to get to from outside. You might look into replacing PPTP with IPSEC and terminating your VPN on the PIX or at least terminating PPTP on the PIX.
Thanks for the reply..
All in bound tunnels terminate on the PIX, and I use both IPSEC and PPTP.
