07-28-2003 09:17 AM - edited 03-09-2019 04:13 AM
Announcement #64 at http://www.cisco.com/en/US/netsol/ns110/ns170/ns171/ns292/networking_solutions_newsletter09186a0080136734.html
says that the S48 update will NOT work with the NRS-xxx sensors. But the README for the S48 update sez that it WILL.
Which is correct?
Henry Schupp
07-28-2003 10:38 AM
Hi Henry -
4.1(1)S48 is not compatible with NRS-xxx sensors.
3.1(3)S48 is compatible with the NRS-xxx sensors according to the 3.x S48 readme file.
http://ftp-sj.cisco.com/cisco/crypto/3DES/ciscosecure/ids/3.x/appliance/IDS-sig-3-1-3-S48.readme.txt
"TARGET PLATFORMS AND REQUIRED VERSIONS
The IDS-sig-3.1-3-S48.bin signature update can be applied to version 3.1 sensors as follows:
You can only apply this signature update to IDS-42xx and NRS-xx series Cisco Intrusion Detection System (IDS) sensors."
The reason for this is that 4.x IDS code is not compatible with NRS-xxx sensors, while the 3.x IDS code does support the NRS-xxx sensors.
The link you mentioned above does not make reference to 3.x code, so I believe that is where the confusion may stem from.
Hope this helps,
peter
07-28-2003 10:43 AM
Peter -
Thanks. That makes sense to me. Re-reading the announcement and README's makes it more apparent. Appreciate the clarification.
Henry Schupp
