same-security-traffic command queries
glenn.ong
Dear experts,
I wonder if putting in the "same-security-traffic permit intra-interface" or "same-security-traffic permit inter-interface" global commands will make the traffic 'bypass' the ACL for interfaces with same security level?
Your answer is much appreciated.
Glenn
The short answer is yes if there is an access-list on the interface then there must be an entry allowing the traffic for it to be allowed back out.
For more details have a look at this document.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080734db7.shtml#t5
Jon
Jon Marshall
Hi Glenn
The "same-security-traffic permit inter-interface" command will indeed allow traffic to flow between interfaces without access-lists.
The "same-security-traffic permit intra-interface" allows traffic to exit out on the interface it was received on.
Please see attached doc for more details.
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/s1_72.html#wp1289167
Jon
Hi Jon,
Thanks for the speedy response.
For "same-security-traffic permit intra-interface" command, will the originating traffic that exits on the same interface still hit the access-list though?
One of our customers have their VPN and thirparty network coming in on the same interface on a FWSM - obviously for VPN-> third party connections, this command is needed to make it work but the connections have to be enforced by ACL too.
Glenn
Jon
