Scanning multiple VLANs using a trunk?
Austin W
Frequent Visitor
Frequent Visitor
Good morning,
i was informed by a new security person at work that he was able to scan multiple VLANs at his last job using thier Nessus Scanner. he said that the networking team at his last job set up a trunk on their switch and the device was able to scan everything, but cant further explain basiclly anything else. after a couple hours of research im stuck. i dont want to tell him no, any thoughts on how the trunk needs to be set up or if it might have to with his scanner needing to be configured differently?
7 Replies 7
balaji.bandi
You can scan  in the network :
explain better in the below video :
https://www.youtube.com/watch?v=T7AuhivO3LI
BB
Austin W
Frequent Visitor
Frequent Visitor
this just seems like how to set up the scanner. the guy knows how to set up the scan. i can set a port on a specific VLAN and he has been able to produce results. what he wants to be able to do is scan all the VLANs at once.
I do not see any issue scanning all VLAN here ?
BB
Austin W
Frequent Visitor
Frequent Visitor
Would there need to be some config on the switch port to make it work?
For scanning it does not require any special config - we do scan all time for the audit network.
BB
do they need to use a crossover cable for that, if they are scanning the trunk?
No not  any cross cable, nesus need IP address to scan, switch port can be access VLAN (what the nesus using IP address?)
If you looking for other methods, the Switch port can be trunk and allow all the VLAN in your network.(Configure nesus with sub-interface to scan.)
BB
