Setting up Azure SAML for Meraki Dasboard
steve.toomey
Hi folks
I've found that the process steps in Azure for setting up the Meraki Dashboard Enterprise app SSO has some steps for the SAML URL in the Dashboard which the Meraki Documentation doesn't include and with no obvious place to configure it. Did anyone find a process for setting this up which are complete and work?
Steve
@steve.toomey you might be better off posting this question in the meraki forum - https://community.meraki.com/t5/Meraki-Community/ct-p/meraki
Thanks for the reply. I’ve solved it now. There was a wrong expectation of the way it would work and one of the settings in Azure marked as optional actually stopped it working. Fixed now
