(shunnig issues) ERROR: Syntax error from invalid input at device
garyprice
I have a k9 4235 setup to shun host/connection using an interface on a cisco 6513(ver) 12.1(19)E
I have updated sig and patch to Version 4.0(1)S48 on the ids. A userid/password that has access to the router/config terminal access level is being used..We are using a TACAS server.
These are the errors that are being logged on the ids device 000.000.000.00 replaces ip of router interfaces... adn zzzzz replaces the name of router
----------beging error log ---------------
evError: eventId=1056707842350918627 severity=error
originator:
hostId: Constitution
appName: nac
appInstanceId: 17778
time: 2003/07/21 14:53:21 2003/07/21 10:53:21 EDT
errorMessage: name=errSystemError ERROR: Syntax error from invalid input at device [Cisco] IP [000.000.000.000] state [Active]Text from device:
onfigure terminal
% Invalid input detected at '^' marker.
zzzzzz# no ip access-list ext IDS_GigabitEthernet1/2_in_1
zzzzzz#
-----------------------end of error lod -----------
It has been runing for 24 hours and there are abbout 50 "failed" attempts to configure the access list by the ids.
If I am reading this correct it appears that the command being sent to the router from the ids is wrong
The "c" in configure terminal is not present....
How can I edit the script so this command can function properly?
Or is there a fix..........
Gary Price
garyprice
sorry I did not notice how the space character dropped out of the log... this messages has been changed to reflect the correct syntax.
well this will not work either... here it is in words
the first syntax error marker should be under and just after the "e" in onfigure terminal.
the second should be under the "i" in
sorry for the confusion, but cut and past is not a perfect science
gp
you have to get rid of all the "#" signs from the configuration. The sensor cannot parse the return it gets from the device properly if there are "#" present.
no # symbols in the config. they only show up as the console prompt....
log into the 6513. Do a conf t then try typing the command "ip access-list ext IDS_GigabitEthernet1/2_in_1". Does that work?
