Now, we are using one source SPAN session for IDS/IPS and the second is used for the SPAN reflector feature. This feature is described in FWSM configuration guide: "This feature enables multicast traffic
(and other traffic that requires central rewrite engine) to be switched when coming from the FWSM. The
SPAN reflector feature uses one SPAN session. To disable this feature, enter the following command:
Router(config)# no monitor session servicemodule"
We want to use the second SPAN session for troubleshooting and so to disable this feature. So I want to know which traffic precisely could be affected?
Andrey, CCNP,CCSP.
