Split Tunnel Problem
john-morales
Community Member
I have a 506e at main site and at the 2 remote sites I employ 501's, the 2 remote sites connect to the main site via VPN. Now until recently everything has worked. Users at each remote site were able to connect to the main site via the VPN and connect to corp. server. The users at the remote sites were also able to browse the internet.
Now the users at the both remote sites can connect via VPN to main site, but they are now unable to browse th internet. Since I maintain the firewalls, I know that the configs have not changed.
So where do I begin, or any suggestions on how to trouble shoot?
Again my problem is not VPN related, that works. But browsing the internet is not working.
7 Replies 7
rolandshum
Level 4
Level 4
Do you have routers behind the remote site firewalls? Do all the workstations use the inside interface on the Pix as the default gateway?
I'm asking because while the Pix may not have changed something behind your firewalls might have. The ACL for the split tunnels might need to be updated.
Yes there are routers, but since the remote sites are using sbc dsl, they are more like dsl modems.
The pix are configured to log on to the sbc site.
All the workstations do use the inside interface of the Pix as the default gateway.
layer9
Community Member
One thing I would suspect is DNS. Whose DNS do you use. Your ISP? Or Internal DNS. Are users able to acces the right DNS servers? I would start there. Make sure that they can PING their respective DNS servers.
Since you are confident NOTHING has changed on the IPSEC tunnel or ACL's, then I would suspect a DNS issue.
Chris Weber CCDP
[email protected]
I am using the ISP DNS, but when I try to ping ISP DNS, I am unable to ping them. But if I disconnect the PIX from the network and use the sbc software to logon to the internet, I get the same DNS servers (ISP's) and I am then able to access the internet. This is PC to sbc router/modem with sbc software.
Can you post your pix 506 config ?
It will make easier to help you...
501 pix config.
I am "x'ing" out the public ip's, and logon names for securiy purposes.
First is the remote pix(501) config:
PIX Version 6.3(3)
interface ethernet0 10baset
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxxx
hostname naperville
domain-name mca.uucp
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside pppoe setroute
ip address inside 192.168.4.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.4.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.4.0 255.255.255.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
vpdn group pppoe-sbc request dialout pppoe
vpdn group pppoe-sbc localname [email protected]
vpdn group pppoe-sbc ppp authentication pap
vpdn username [email protected] password *********
dhcpd address 192.168.4.100-192.168.4.131 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
vpnclient server x.x.x.x
vpnclient mode network-extension-mode
vpnclient vpngroup mcagroup password ********
vpnclient enable
terminal width 80
Ok, now here is the 506 pix config:
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 auto
passwd xxxx
hostname Pix01
names
access-list 101 permit ip 192.168.1.0 255.255.255.0 192.168.4.0 255.255.255.0
access-list 101 permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 101 permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.128
ip address inside 192.168.1.254 255.255.255.0
ip local pool mcapool 10.0.0.1-10.0.0.254
pdm history enable
arp timeout 14400
global (outside) 1 x.x.x.x
nat (inside) 0 access-list 101
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set mcaset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set mcaset
crypto map mcamap 10 ipsec-isakmp dynamic dynmap
crypto map mcamap interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup mcagroup address-pool mcapool
vpngroup mcagroup split-tunnel 101
vpngroup mcagroup idle-time 1800
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
