sqlplus problem with access-list
costaskyrri
Community Member
I have configured my ios firewall with the inspect commands and have opened the port 1521 in my access-lists, when using my sys log program to see, why it does not connect, i see that it starts up fine using 1521 and all of a sudden i see other ports being created from that source eg ports 2480 and so on, it creates ports by random after wards. If i use say port 80 for browsing that works fine or ftp which is 21 and 20, if I telnet 1521 it works, only when I use sqlplus it does this strange thing , creating random ports. the ios used is 12.2 with firewall.
I have other sites connected to my site which have the same config and they work fine.
the commands uses are
access-list 150 permit tcp host 10.171.12.30 host 10.133.41.3 eq 1521
access-list 150 permit tcp host 10.171.12.30 host 10.133.41.3 eq 21
access-list 150 permit tcp host 10.171.12.30 host 10.133.41.3 eq 20
access-list 150 permit tcp host 10.171.12.30 host 10.133.41.3 eq 80.
paddyxdoyle
Level 11
Level 11
Is this an oracle server.
I have seen problems with this in the past as sqlplus listens on 1521 but it then creates random ports for the remaining connections. This will break when passing through a firewall as the firewall won't have these random ports in its policy and thus break the connection.
I'm afraid i'm not familiar with Oracle but i found an interesting thread with people having similar issues to you with a fix by hardcoding the random ports on the oracle server and allowing these ports back in through the firewall.
http://ora-12571.ora-code.com/msg/41100.html
Paddy
