SSL/HTTPS intermited problems
funraps
Level 2
Level 2
I am doing port forwarding, one public IP.
www going to x.x.x.x works fine everyt time
https going to y.y.y.y sometimes works and sometimes does not, any ideas?
nkhawaja
Best Guess is that you also enabled HTTPS on the PIX. Try to disable HTTP server on the PIX and see if that helps
Nadeem
nkhawaja
Nadeem
I disabled it, will try it out... why doesn't it work properly?
Thanx
