STATIC STATEMENT WON'T WORK
robysolutions
Community Member
I have setup plenty of firewalls using the exact same command and never had trouble until today. I have configured a pix using the following parameters for NAT'ing.
ip address outside 21.106.223.150 255.255.255.128
ip address inside 192.168.1.0 255.255.255.0
nat (inside) 1 0 0
global (outside) 1 interface
static (inside,outside) 12.106.223.131 192.168.1.3
The problem is everytime I enter a static command for any internal IP address that machine can no longer access the internet or go outside of the network (weird thing is sometimes it will work and the configuration is exactly the same). I need these static for webserver purposes. I have used clear xlate and clear arp but nothing. The moment I remove the static command and clear xlate the IP address works fine. What is going on!!! This is a used pix 520 that was purchased a couple of days ago and I am starting to wonder if the device may be defective.
7 Replies 7
robysolutions
Community Member
I made a typo, the outside address is supposed to be 12.106.x.x
Config is fine, please could you check the logg messages on the PIX for error messages.
What version of PIX OS are you using.
Are you sure that this host has not problems with Duplex of other configuration issues, check IP setup and default gateway.
Do you have an access-list on the inside interface?
logg on
logg buffer info
show logg
sincerley
Patrick
version 6.4(3)
the host can ping fine when the static statement is removed and a clear xlate command is issued. There is no access-list applied to the inside interface, only outside allowing ICMP.
Correction:
Version 6.3(4)
What are the logging messages when you connect from the outside to your web server ?
Have you verified your Server setup ?
is duplex mode on switch and Server the same ?
Routing ok, default gateway = PIX ?
sincerely
Patrick
The problem isn't that I can't access the server from the outside, but rather that the server can't pass throught the pix when a static command is issued referencing the local inside ip address to a global IP address. The moment I remove that static and allow the server to be PAT'ed, it works fine. It can pass through the PIX. The duplex modes are all fine and so is the gateway because all machines on the inside of the firewall can route outside just fine until I use any type of static command.
what services are u running on that server ? please try opening ports from outside and see if you are able to reach the server on that port from outside. for eg, if it is a web server, try telnetting the natted IP on port 80 from the router and see if NAT is happening fine.
also, try changing the outside IP to someother unused public IP and then try connecting from outside.
Hope your ISP routes the entire pool of public IP. Do a static and try doing a reverse trace from route-server.ip.att.net. see where it drops. might be something to do with ur ISP...
Raj
