08-20-2004 09:05 AM - edited 03-09-2019 08:32 AM
my 501 has default config:
fixup protocol sip 5060, and
fixup protocol sip udp 5060
can anyone tell me the differenc between these two fixups and the STUN protocol which is what my sip phone supports?
do later versions of PIX support STUN?
THANKS!!!
08-20-2004 09:28 AM
Command Reference 6.3.x
See: http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_chapter09186a00801727a8.html#wp1067379
Fixup SIP:
SIP Enable or change the port assignment for the Session Initiation Protocol (SIP) for Voice over IP TCP connections.
UDP SIP is on by default and can be disabled and the port assignment is nonconfigurable. PIX Firewall Version 6.2 introduced PAT support for SIP.
VoIP Guide for PIX:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00801fc74a.shtml
There might be some better documents on:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/prod_configuration_examples_list.html
sincerly
Patrick
Log in to Community
