Traffic between interfaces with same security level not working well
br
Dear all,
we are using a PIX-515 with IOS 7.0(2). In our configuration we have defined following interfaces:
interface Ethernet1.20
description Internal ISN-1
vlan 20
nameif ISN-1
security-level 80
ip address 10.254.130.253 255.255.255.0
interface Ethernet1.30
description Internal ISN-P1
vlan 30
nameif ISN-P1
security-level 80
ip address 10.254.129.253 255.255.255.0
interface Ethernet1.40
description Internal ISN-P2
vlan 40
nameif ISN-C4H
security-level 80
ip address 10.254.131.253 255.255.255.0
We added this option to make sure the traffic is flowing freely between these interfaces (just normal routing, no firewall rules):
same-security-traffic permit inter-interface
Unfortunately we encouter strange problems because traffic from interface ISN-P2 to ISN-P1 is working but traffic from ISN-P2 to ISN-1 is not working. We have no error or deny messages in the log of the firewall, it's just not working.
Even when adding allow-rules like "access-list allow_all extended permit ip any any" on every interface (using "access-group allow_all in interface ISN-*") does not change anything.
Please help me to find the problem. Feel free to send me some hints how to find out what's not working.
Best regards
Bernhard Roth
george.goebel
Community Member
Since this topic is two weeks old I'm sure you probably have figured it out by now. But, just in case you haven't, interfaces with the same security level will never talk to each other. It's just the way the pix works. Change the security level on one of them and it will probably work.
Now everything is working, thanks to your help. The problem was that we connected the pix to a quite heavy loaded network segment (as a replacement for a linux firewall) and all the filters were (by default) switched on for every interface. As a result the pix was overloaded and was some kind of stucked. After we changed the policy to be only active on the outside interface it worked fine.
Thanks to all your help. The new pix os 7 is great, much better in adminstration and performance that 6.x 🙂
best regards
bernhard
mdufault
Frequent Visitor
Frequent Visitor
Don't use the same security level. PIX work on high to low or low to high and not same to same.
Currently we are (ab)using the pix as firewall/router. As next step we will remove the "same-security-traffic permit inter-interface" setting and configuring access rules in both directions for same-security level interfaces. The conceptional problem is that there is not really an interface with a "higher" security level as all are customers/service areas are equal. We want to specify allowed traffic in both directions and not block one interface to all others with lower security level. The configuration is getting quite complex, isn't it?
