UDP 500 and ESP
agoodwin
Can anyone tell me a bit about ESP please? I can setup my router to allow through udp 500 but I assume I need a more specialised one to allow ESP - or does it just need other ports? A website would be good?
Apologies for possibly being a bit daft with this question
thanks for your time
Andy
ywadhavk
I guess you are asking about VPN tunnel. In that case,
ESP = port 50
AH = port 51
and
UDP port 500
These are the ports you require to open up. In addition, if IPSec over udp is used then UDP port 10000 needs to be opened.
As for ESP (Encapsulating Security Payload), please refer to RFC 2406
and more info on the below url;
http://www.cisco.com/en/US/partner/tech/tk583/tk372/technologies_tech_note09186a0080094203.shtml
yatin
ywadhavk
ESP = port 50
AH = port 51
and
UDP port 500
yatin
Hi Yatin,
I feel ESP and AH are Protocols and 50 and 51 are Protocol numbers.
Thank you.
Murthy.
Murthy,
Ofcourse they are. I didn't think the '=' sign will be taken literally..
Yatin
Thats exactly what I needed - thanks for your help,
cheers
Andy
