Using CyberArk to manage local IOS account passwords using high port SSH
Santa.Hawes
We currently are attmpting to integrate a CyberArk Central Policy Manager for the purpose of managing the local account password for accounts on our routers and switches.
Users log into each router/switch using ISE & RSA Mutilfactor authentication on SSH port 22. Currently, the configs force SSH only, and always on port 22.
I have a solution that involves having CyberArk log in on a restricted upper port (>1024) using just SSH and a significantly complex password.  We have the functionality working in our DEV environment using the following coding:
version 12.2
aaa new-model aaa authentication login local-auth local aaa authorization exec local-auth local ! ip access-list extended CYBERARK permit tcp host xxx.xxx.xxx.59 any eq 3022 ! line vty 14 15 access-class CYBERARK in privilege level 15 authorization exec local-auth login authentication local-auth rotary 1 transport input ssh !
However, when we take these same changes into out test validation lab, nothing is listening on port 3022.
Any Ideas?
Any thoughts, comments and/or reactions made by the above identified individual are the sole responsibility of the above named individual, and should not reflect on his employer, spouse or family name.
Amine ZAKARIA
Did you use ip ssh port 3022 rotary 1 ?
debug ip ssh what does it show ?
